Amis bidouilleurs, bonsoir !
Seriez-vous intéressés de faire afficher une image vidéo sur un oscilloscope CRT ?
One more video playing with the Z-axis input on an analog oscilloscope. This time, I turn the scope into a composite video monitor by creating X and Y sawtooth ramp signals from the vertical and horizontal sync pulses. For this hack, I use an LM1881 Composite Video Sync separator to easily extract the sync pulses from the composite video, then a couple of transistors to create the sawtooth waveforms, and finally a simply inverting amplifier to invert the video signal so that the resulting image on the scope is not a negative image. Then, I take a little lab equipment tour, using the scope video monitor to show the equipment (just for fun!).
Note: I made a little tweak to the circuit to enhance the vertical linearity and video contrast. The 10uF cap in the vertical ramp circuit was changed to 0.1uF, and the corresponding 680ohm resistor in the current source feeding that cap was increased to 68Kohm. And, I changed the 39nF cap that creates the horizontal ramp to 22nf to increase the amplitude of it a bit. More careful power supply decoupling got rid of a lot of the noise on the ramps, and sharpened the video. Also, I lowered the value of the collector resistor in the video inverter to lessen the contrast on my scope. This « gain » change will be scope dependent - set the gain as needed to get the contrast you want on your scope based on your video amplitude and scope z-axis sensitivity.
A few more tweaks… I added an adjustable gain stage for the composite video amplifier so that it can accomodate the Z-axis gain differences on different scopes. I also added an inverter for the X-Axis ramp signal, so that I didn’t have to invert it on the scope. My old 485 uses Ch2 for X, and CH2 has an invert switch. However, many other scopes use CH1 for the X input, and thus typically would not have the invert function. If anyone wants details for these additional changes, please let me know.
y’avait eu un article par des ingénieurs de Tektronix pour afficher une image video avec deux scopes serie 5xx.
Sans montage annexe et en utilisant uniquement les fonctions des scopes: déclenchement et sortie de la dent de scie du balayage qui est accessible sur presque tous les scope 5xx
Si je me rappelle bien, (j’ai recherché cette note d’application mais je ne l’ai jamais retrouvée).
le premier scope servant pour générer le balayage vertical et le deuxième visualisant la video avec l’entrée z, en utilisant la dent de scie horizontale du 1er scope pour son déplacement vertical et sa base de temps pour le balayage horizontal.
c’était la coup classique pour regarder l’arrivée du tour de france dans les labos d’essais
le récepteur était un analyseur de spectre 141T qui a la particularité d’avoir une sortie détectée AM
Montages pour cette manip:
Ce projet s’inspire du convertisseur VGA-to-Scope en utilisant la vidéo composite plutôt que les signaux VGA pour créer un affichage sur un oscilloscope. Les circuits du convertisseur VGA vers Scope ont été considérablement simplifiés ; les tampons d’ampli-op et les onduleurs ont été éliminés. L’alimentation en courant continu pour charger le condensateur de manière linéaire (le transistor 3906 PNP et les résistances associées) a été remplacée par un simple pot de 1Meg de 5V pour charger le condensateur, tout en créant une dent de scie non linéaire. Lorsque le potentiomètre est réglé correctement, le condensateur se chargera au rythme correct et le signal de déclenchement amènera le 555 à décharger le condensateur pour la synchronisation.
https://www.electronixandmore.com/projects/tvtoscope/index.html
J’ai souvenir d’avoir joué a ça avec un analyseur en zero span pour fournir la vidéo.
Il me manquait juste un autre analyseur pour le son.
Sinon chez tektro il y avait un oscillo spécial TV avec une sortie vidéo ou la zone affichée sortait
noircie sur un moniteur.C’était un très vieux appareil tout a tubes trouvé a la casse.
pour cela il y avait la poste de radio du labo , le commentaire n’etait pas toujours très en phase avec ce que l’on voyait …
J’avais joué à regarder le tennis de Rolland Garros en Juin/Juillet 1986. Via Canal+ en VHF.
C’était à Matra Communications de Bois d’Arcy. J’étais censé faire des mesures sur Radiocom 2000 dans le labo radio …
Pour l’image seule, il m’avait fallu un analyseur de spectre, une antenne fouet à ventouse collée à la fenêtre, et trois oscilloscopes.
Un scope était utilisé uniquement pour amplifier le signal vidéo, avec sortie Y.
Un autre scope faisait le balayage trames avec sortie X.
Un troisième scope recevait la vidéo amplifiée sur l’entrée Z wehnelt et sur l’entrée synchro, et le balayage trame sur l’entrée Y. Il devait faire le balayage X avec synchro ligne.
Et il fallait regarder avec le cache en plastique car l’image était peu contrastée. Sûrement pour cause de spot trop gros pour une image TV.
L’objectif de ce projet était d’afficher de la vidéo sur un oscilloscope sans nécessiter une entrée de modulation Z externe.
Quant à l’atteinte de l’objectif, le projet est une réussite majeure car le convertisseur vidéo obtenu permet d’afficher le signal converti sur un oscilloscope sans avoir besoin d’une entrée mod Z, ainsi que sans avoir besoin d’une entrée X, puisque la rampe X/ le balayage est généré par la base de temps déjà présente qui est déclenchée par des impulsions de synchronisation vidéo.
Le principe consiste à utiliser une onde carrée PWM superposée à une rampe de balayage verticale qui aboutit à deux champs dessinés empilés l’un sur l’autre. Le champ inférieur est l’image de sortie principale et le champ supérieur se trouve être l’image inversée (les noirs sont blancs et vice versa) du champ inférieur, ce qui est dû au principe de l’utilisation de PWM pour que la trace reste dans le champ inférieur lorsque un blanc est souhaité, ou faire sauter la trace vers le champ supérieur lorsqu’un noir est souhaité. En modifiant le rapport cyclique de ces sauts, la luminosité perçue de la trace peut être continuellement modifiée, tout comme le ferait la modulation du courant cathodique dans le CRT, mais dans ce cas, elle reste constante
Schéma à 1:33
